Perform this procedure to view capabilities information for remote LLDP-MED on specific ports based on the information advertised by the remote device and received on each port in the capabilities TLV.
- Select Port MED.
- Select the Neighbor Capabilities tab.
Neighbor Capabilities Field Descriptions
Use the data in the following table to use the Neighbor Capabilities tab.
| Name | Description |
| TimeMark | Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
| LocalPortNum | Specifies the port on which the remote LLDP-MED information is received. |
| Index | Specifies the connection instance unique to the remote LLDP-MED. |
| CapSupported | Specifies the LLDP-MED capabilities supported on the remote system. |
| CapCurrent | Specifies the LLDP-MED capabilities that are enabled on the remote system. |
| DeviceClass | Specifies the remote LLDP-MED device class. |
